I'm having a starting problem with my 2000 truck. It's blowing starter fuses, and I can't seem to to find any places in the wiring where it may be shorting. I found the TSB calling for replacement of the 20 amp fuse with a 25 amp, and another calling for the same thing, but also replacing some of the wiring.
I replaced the 20 amp fuse with a 25 amp, but it's blowing that as well. This truck has about 95000 miles on it, and I'm betting the starter contacts are probably on their way out. But could marginal starter contacts cause the fuse to blow like this?
Thanks,
Mike
Thanks,
Mike
