Truck keeps losing fuel prime
727 to 47rh
rear differential bolts
Every morning I have to hold my foot to the floor and have the truck plugged in to get it to start then I have leave it floored for a few minutes to get it to clean up and have any power. It started after I put in the new fuel sending and pick-up unit/fuel pump module. Any help is greatly appreciated.
Could be a bad seal on the quick disconnects at the tank but I am told you have to buy the complete lines to replace the seals. Mine was cracked at the tank on the module but thank goodness it was the return fitting and I did away with the quick disconnect and put a hose and clamp on it.
