i was cruising down the freeway at 70 mph when my truck made a bang and the check engine light came on. the truck started coasting and it wouldnt respond to any throttle, so i put the truck in neutral and then the truck would rev when i pressed the throttle so i put it back in gear and everything seemed good except it wouldnt shift into overdrive for about 15 min. then it shifted and it seems to be running ok but the check engine light is still on.
the trans has been shifting kinda strange the last few weeks and it shudders sometimes when its in o. d. and going up a hill. it also acted the same last sept. so i took it to the dealer and they flashed the comp. and it did help some but towing my car trailer it still shuddered some. im thinking the trans is getting ready to go. i have an ext. warranty so maybe if it is the trans. i'll get a new one out of it.
any ideas??
TIA
any ideas??
TIA
