I have a 2000 4x4 with 100,102 miles. At this point the truck seems to only start when it wants to.
Sometimes the truck will start just fine and other times it just cranks away but will not start. You can kick it, slam the door and walk away, then come back 30 minutes later and it will fire up.
Fuel filter is only a month old, lift pump is working, 14 psi. If it starts, it will fire up as usual with no stutter or hesitation. It seems to want to fail if you drive it, then let it sit for 30 minutes. I can always restart it right after shutdown, it has to sit for at least 15-30 minutes before it acts up. It will always start in the morning and in the evening when I leave to go home from work. Just DON'T take it to lunch.
The check engine lights up when it happens but it only gives me the 1693 code which doesn’t mean much. I have unplugged and replugged every connector I could find under the hood. I even removed the EZ but none of this seemed to help.
Could it be heat related??? Could it be the computer that is on the firewall behind the air box??? I don't think it could be the injector pump, because, if it starts, it does "start" and run normal. It will also keep running until the next time you try to start it.
Any help or experiences would be greatly appreciated. I now do a little prayer just before I try to start it. This has seemed to help a little but it has not fixed the problem
