I'm working on 2002 model automatic truck. The codes it shows are po 606, 118, 238, 343, 563, 606, 1286, 1475, 563, and 118. Truck is showing high voltage on scan tool and the gauges in the truck, like 15. 2 on the scan tool. The throttle is irratic, and normally if you touch it, the truck will go full throttle. It's showing high voltage to the transmission also. The temp gauge after startup will peg at 240. I've replaced the pcm, ecm twice, i took fuse out for alternator and still had an overcharge on scan tool. checked battery's and did't show an overcharge, 14. 2 volts. Cleaned serveral grounds. When heat gauge goes to hot, is when truck acts up, after about 30 secs of running. Replaced APPS too. Please Help! Thanks!
