Well it got really cold here tonight down into the single digits and I work 2nd shift and when I went to leave work the truck started ok for being cold and I idled it for a few minutes and then when I went to leave while driving about 10-15 mph's it started to loose power and was smoking terrible and finally died took several crankings before it fired up drove another block and it did it again and it sounded like it wasn't fireing on all cylinders. Got to a truck stop by the interstate and got some Howell fuel additive to stop jelling as I was quessing that was what was happening and let it idle for awhile and took off needless to say 40 mph was all I could do and it still lost power and died several times on the way home. I do not know if the fuel I got was climatized or not do you guys think it was trying to jell on me or could it be something else that I need to look at. To make things worse my passenger side door will not latch now either
and all work has to be done outside and it is Cooold.
Sorry this is kind of long but any and all help will be appreciated.
Thanks,
Paul
'96 2500 ext. cab, LB, 4x4, 5 speed, 3. 54, TST 280 cam plate, AFC spring kit ,pyro and boost gauges mounted on A-Pillar, tinted windows, 16x8 Eagle alloys series 1219, 285/75R16 Durango A/T's, stainless steel rocker panels and alluminum stirrup steps
Thanks,
Paul
