Engine/Transmission (1994 - 1998) Truck starts then dies
Engine/Transmission (1994 - 1998) Modded 94....low power???
I started having a problem with my 96 after I filled up the tank (home b100 for 1+ yr) Thur night. I Went to leave for work Fri. morn and it started fine, warmed up for a little bit and then died when I pulled out of the driveway. Acted like it is was gelled or plugged filter (high 30's overnight that morning). Got home from work Fri. afternoon, started fine drove up road and parked in shed. Changed fuel filter out today, it was close to time anyway, and I still have the same problem. If I let it sit 5 min it will fire back up and run for 2-3 min and then die again. I am suspecting issues with the last batch of fuel, although it did process/look the same as all my other batches. Would a weak lift pump have symptoms like this? Any other ideas short of emptying the tank and running some straight diesel thru it to see if it still does it?
Thanks,
kkitelinger
Fuel pressure test , overflow valve for pressure , then lift pump .
You can slowly pinch the return line to check overflow valves ability to work .
If pressure does not rise with return pinched then lift pump .
