Truck surging running rough
Valair clutches
NEW Southbend ConOFE in my 2007. My impressions
My dad's '03 has started to surge at idle sometimes and will stumble sometimes when starting out. It has a FASS on it and had an EDGE EZ on for a while (lowest setting). Would the FCA be the problem? It throws no codes. Need some help diagnosing the problem.
I can not remember, but I think it is Steved who brought up the A/C wiring right above the oil filter rubs and creates a short. It can be intermitten. I am not sure but you can at least check it out. I know there is a write up about it. I just dont remember where right now.
The FCA part number is the same on all trucks? I found a PN on another thread and the least expensive that I can find it in Canada is $200. I will check out the AC wiring. With the Canadian dollar going up I might look into one from the US.
Cummins P/N for my 03 is 4932457. I think it is the same P/N for all 3Gen's. I think the price was about $120US a couple of years ago.
The AC wiring rubs bare on a bolt on the rear of the AC compressor... it does cause some weirdness. I found mine worn through quite a bit of wiring insulation, with a fairly large bare spot. It caused a rougher than normal idle... the truck actually started hard initially once it was repaired (like the PCM/ECM were relearning a new parameter).
I remember reading it is a combined circuit that also serves the crank/cam sensors?
Been a while since I read that... this was a common thing in 2003/2004... and its in the archives here at TDR. I cannot take credit for discovering it, only for remembering it from way back.
Your symptoms however, sound like a failed FCA. The cycling idle are very characteristic of a failed FCA...
Thanks for the help guys. Anyone familiar with N14's I am having trouble with my throttle cutting out in my T-800.
