Harvey, GO back to you're DOT manual. A trailer over 10,000lbs , towed by a truck UNDER 26,000 requires a class B CDL. A truck over 26,000, towing 10,000 plus requires a class A. It's GVW not CGVW. Big difference! If you could get a class A lic. with a one ton and a heavy trailer, everyone I know would have one. please check your facts before you expound.
Nice try but you don't know what you're talking about.
This is a cut and paste from the Federal Motor Carrier Regulations:
"Classes of License:
The Federal standard requires States to issue a CDL to drivers according to the following license classifications:
Class A -- Any combination of vehicles with a GCWR of 26,001 or more pounds provided the GVWR of the vehicle(s) being towed is in excess of 10,000 pounds.
Class B -- Any single vehicle with a GVWR of 26,001 or more pounds, or any such vehicle towing a vehicle not in excess of 10,000 pounds GVWR.
Class C -- Any single vehicle, or combination of vehicles, that does not meet the definition of Class A or Class B, but is either designed to transport 16 or more passengers, including the driver, or is transporting material that has been designated as hazardous under 49 U. S. C. 5103 and is required to be placarded under subpart F of 49 CFR Part 172 or is transporting any quantity of a material listed as a select agent or toxin in 42 CFR Part 73. "
A class A cdl is required, as I said, for pick-up/trailer combination vehicles where the trailer weighs or is rated to weigh 10k lbs. and the combined weight is over 26k.
You have some confused misunderstanding about a class B license which is for heavy single vehicles such as box trucks or passenger buses weighing more than 26k or when that heavy single vehicle is towing a trailer weighing less than 10k. A class B license is NOT for combination vehicles as described in my paragraph above.
Until recently when I became certain I was not ever going to tow commercially again and voluntaraily surrendered it, I had a CDL A license which I obtained with a pickup truck. I drove my '06 DODGE RAM 3500 AND TOWED A BORROWED GOOSENECK FLATBED TANDEM AXLE DUAL WHEEL TRAILER TO OBTAIN A CLASS A CDL. All that was required was an ordinary dually and a trailer with a GVWR of 20k. The combination was well in excess of 26k although actual scale weight the day I took my driving test was probably not more than 18k to 20k.
YOU should try to get a clue what you are talking about before you correct me.
Doubt me? Look it up yourself in the Federal Motor Carrier Regulations.
