My first time to post, so hopefully I don't break any rules. Filled up my truck ('99 24V 4X4, Auto Quad Quad) with fresh fuel after sitting almost pegged on empty. Ran fine for 15 miles all the way home. Went out 2 hours later it started then promptly died 5 seconds later and will not start.
Here's what I've looked at:
Drained some fuel from the water separator, seemed clean with no water. Thinking bad fuel.
Cracked the banjo on the filter top from the Lift pump and had my son bump start. No fuel from fitting. I can here the LP cycle, but does seem to sound different.
Drained water separator/filter and with drain open bump started and no fuel from from drain hose.
Took fuel filter off and looks clean (changed 5,000 miles ago)
Tried to read codes using on-off-on-off-on procedure with no luck. I'll try again. Maybe run to Auto-Zone for a reader and pressure gauge.
I'm thinking lift pump is bad and hopefully the Injector Pump hasn't failed also. My plans are to put a new fuel filter in and a lift pump in the morning ($245 from dealer). Am I on the right track? Anything else I can do to diagnose either pump? I don't have a fuel gauge installed but after this it will be my next purchase. I'm in a time crunch now. My family and I are supposed to be on the road the day after tomorrow. Navy's moving us from Jacksoville, FL to Colorado Springs, CO to play with the Air Force. Luckily, my father-in-law has lots of tools. Mine are packed up. Any advice would be greatly appreciated. Thanks.
