Hello Guys,
I went to drive to work this morning and got about two blocks from the house and my truck started surging. I would push on the accelerator and nothing would happen then the truck would surge a couple times and then drop back to an idle (gages all looked normal). I turned around and bucked my way back home. Just as I was pulling up to the house the check gages light came on and I looked down and the temp gage was maxed out. Turned it off and now wondering what to do next.
It never died, but when I hit the throttle nothing happens for 30 seconds then it will surge for 5 seconds and drop back to idle. I just went out and started it again and without pushing the accelerator it surges while trying to idle. The engine does run but the truck won't move.
I was thinking it was a lift pump or vp44 but the overheating has me stumped. In never boiled over but the gage was maxed out at 240+ degrees. Any help will be appreciated.
It's stock with the exception of a 4" exhaust, afe pro guard air filter and a pack brake. Only has 18,000 miles.
Any ideas would be greatly appreciated.
Thanks a million,
Thanks a million,
