Hello folks, first off, thanks for the information in this conference.
I have a 1992 Ram 250 LE 2wd with 146K miles on it that went from running perfect to instantly missing and not idling while going 4th gear up a pretty good grade. I let water out of the separator, and the sputtering stopped and power pretty much came back, but the idle never did. I replaced the filter/separator, refilling and priming/bleeding as directed. Bled air out of the low pressure bleed using the lift pump, and at the injector fittings while the truck was running.
It idles fine some of the time, then it really dies off, barely runs, oil pressure goes low, etc. (I turn it off so as not to run the engine under this condition). Power is normal - and at times when cold in the mornings, seems much better than normal.
I bled the system several times as mentioned above, and got air all but the last time. One interesting note, the injector closest to the front of the truck, which makes it last in line for fuel, would not bleed air or fuel until the motor was revved. At high idle, no fuel appeared to be there.
Any suggestions to figure this one out? Thanks for any help!
Jon.
Jon.
