Engine/Transmission (1998.5 - 2002) Truck Won't Move! Help transmission Problem
Engine/Transmission (1998.5 - 2002) Dse
Engine/Transmission (1998.5 - 2002) Diesel Secret? Anyone use this stuff?
The other day I was moving my Automatic to a new parking spot at my house. I moved it a couple of yards, then I put it in park and then wanted to move it again. BUT, the truck won't move as I go through the gears-- just revs-up like it is in neutral? As I go through the gears it sounds like something it happening and when I try and put it in Park, I get a slight grinding sound but smooth shifting in the rest of the gears. Anybody know what's up??? the truck rolls like it is in neutral.
Thanks!
A local guy asked me to rebuild his trans, I started it, realized it was trying to go, then pulled the transfer case shifter and it ground!! He said why is it in neutral? I said maybe from all the JUNK in the cab? Money saved I said. He is the type of guy who doesn't understand or care about his vehicles.
Always check the simple things first!
