Sounds like the slave cylinder to me. Parts stores like Napa can sell you just the slave cylinder (about 80. 00) the dealer will only sell the complete assembly,(master cylinder,hose,slave). Before doing anything make sure that the fluid resevoir is full. If it is low you could have some air in the system and that will require bleeding. My prefered way to bleed these slave cylinders is to slowly stroke the slave cylinder rod completely in and then let it come back out on it's own. Repeat about 10 times. This will purge the air to the highest point, the master cylinder resevoir. Note the slave has to be unbolted from the bell housing to do this, only 2 13mm nuts. Hope this helps.
