Tonight I started the truck, engine ran very badly, very rough.
Turned it off immediately, tried to restart, no dice.
MIL is on, and following codes are set:
P1693 Companion code DTC-9
P0230 Transfer pump circuit out of range
Transfer pump runs for a few seconds at key on,
and for 30 seconds if you bump starter (normal).
But I noticed once or twice, pump ran for a several seconds after key was turned off.
I don't think this is normal, I certainly never noticed it doing that before.
When pump runs, fuel pressure is perfectly normal.
Does the P0230 code disable starting (via the injection pump or some other way) because it's not happy?
Please help, Important doctor's appointment day after tomorrow,
Thanks
Thanks
