Archived truck wont start wont crank
Archived need vp 44 gear puller
Archived Shifting really hard to 3rd and 4th
truck was running fine shut it off for about 5 minutes went back out turn key nothing everything else seems to work good lights radio this is the third time just kept pulling fuses and checking them no blown fuses the other two times if finally started this time it just wont go need help in truck is in front of restraunt that donates oil for my biodiesel cause.
Try turning on lights and attempt to start. If head lights don't dim a lot probably starter solenoid contacts or starter relay(exchange with another say horn). Quick test when you have no multimeter, etc. CODES? Other possibility if a neutral switch if auto or clutch switch if manual(than can be jumpered out if necessary to get you going. There is a start I hope it helps.
is the truck clicking or attempting to turn over? If not then make sure your shifter is all the way in park and then try it.
