You definetly have an injector going bad
Again I had a hard time starting it today. No codes. I didn't try ether, but after trying it every 15 minutes, it started up 3 hours later (I was cleaning the garage, no big deal). It was 50 degrees out, so not cold at all and good batteries. Only have 40K miles on an '03 ISB-305 HO motor. Truck runs perfectly fine when started. When an injector goes south, does it stick open?
Is there a diagnostic for checking them?
Finally, how difficult are injectors to install and is there a preferred type for an ISB-305? I have a Smarty but don't drive it that hard. Any preferred vendors? Sounds like simple questions, but I know little of this common rail (other than I like it)
Thanks!
, true, the injectors are most likely to fail on the return side, and yes, no code unless its an electrical failure on the injector...I thought you had your injectors replaced, they should of done an injector return test, and most likely replaced all 6, and once again you won't have a code when an injector goes bad
Most People Know It Is A Bad Injector Or Injectors, If Or When The Truck Starts, ( But Runs Great When Started ) Usually Leads To The Bad Injector Issue, Several People Have Had This Problem, Not Saying That Is The Case Everytime, But It Usually Is, You Are Right Go Through The Process Of Elimination First...![]()
