Details here: TDR Privileges
I just installed a fuel pressure gauge and changed the pyro thremocouple and now it won't start. I have cycled the key switch to run the lift pump 5or 6 times also opened the water in fuel valve and a little air came out but still no start.
crack a couple of injector lines up on the head. turn the key so that the motor crnks for a second and then the lift pump will run for awhile. when fuel starts to come out, tighten the lines back up. it should fire right up.
