Engine/Transmission (1998.5 - 2002) Truck wouldn't die!
Engine/Transmission (1998.5 - 2002) Lift pump noise?
Engine/Transmission (1994 - 1998) NV4500 3rd gear grinding
I got back from a short trip today, and the truck would not shut off. I turned off and removed the key and that killed in cab electrics, but not the engine. So i started looking at relays and ended up pulling the fuel system relay. That did it, but i am not sure what had happened. I switched that relay with another one and everything seems fine now. What happened? Stuck relay? Randy:confused:
