Engine/Transmission (1998.5 - 2002) Truspeed Installation
Hello All!!
I just bought a Truspeed module for my 02. In the instructions, it indicates that the speed sensor is located on the ABS controller. Can anyone tell me where the ABS controller is? Any information on the installation of this product is greatly appreciated.
Drivers side between the firewall and the power center (the black box with all the fuses and relays.
But I thing the sensor is located on top of the rear axle housing.
TC
Well, I should read the instructions closer. It says "On late model Ford and Dodge, locate the appropriate color-coded wire on the ABS Module. I am guessing that is the box that you mentioned on the firewall? Thanks for your help!
I installed an Abbott ERA box & tied into the wiring at the PCM. The PCM is located behind the air box. Not sure about how the TruSpeed wires but the ERA connects there.
Clay
