I have had an engine miss / stumble for about a year now. I have done the following things trying to diagnose the problem. (No codes set)
IAT
MAP
APPS
Stock ECM vs Marco ECM (no difference)
Swapped out injector pumps
Swapped out injectors / tubes
Checked and cleaned all grounds and electrical connections
The best way to describe it, Feels similiar to transmission shudder, but very faint. It is much worse when adding fuel, and when damp or raining out (feels like a gasser w/ a bad wire)
I am running with a DTT transmission, Marco ECM, TST3, and EDM 180 HP injectors... Fuel pressure is a solid 16 to 18 psi. No boost leaks.
Head has also been fire ringed and 12mm studs.
Anyone have any ideas?
IAT
MAP
APPS
