Engine/Transmission (1994 - 1998) trying to fix before DHRA nationals
2nd Gen Non-Engine/Transmission Testing the Wheel speed Sensor
D
Engine/Transmission (1994 - 1998) 5 speed transmission fluid?
My truck will break-up , sputter and blow white smoke at around 2,000 rpm. It first started once in a while after sitting for a while now it is almost everytime I start it up. I used to go away after I ran it out "It seemed like air". Now it runs rough at 2000 allot with or without a loud on it. Plus It would sound like it was missing in the upper rpm when i was getting on it "starving for fuel". I put a 10 plate back in an it doesn't seem to starve anymore. Still breaks up at 2000 rpm area. Fuel pressure seems good, but drops to around 15lbs when I am running hard down the road "my buddies increases". The breaking up started more frequently after I timed it.
Please Help! 370 injectors will be in tuesday I hope it helps it. Time is short before DHRA Nationals
Your fuel pressure is low running down the road it should be in the 25-35 lb range
and like stated above your timing could have slipped. Check your fuel filter and over flow valve
