I'm trying to separate the vp44 shaft from the gear housing. My question is how do you know when it's done? I cranked on it awhile using a Blue Chip gear puller and decided to stop because I haven't heard a pop or anything to indicate that it's free. Someone I know at a diesel shop that works on the CTD told me that when the gear comes loose from the pump shaft, the gear puller should be loose and not tight any more. . I'm beginning to wonder about that bit of advice. I cranked on the puller that I have untill I began to worry about breaking a bolt or dislodging the timing case, so I quit. I would appreciate any suggestions.
