Hi, I have been having trouble figuring out where this problem is coming from. When driving down the highway, if the truck hits a bump, it will sometimes start vibrating in the driveline. It seems that the rear driveshaft is vibrating on the slip yoke at the rear of the transfer case. I know this because i have already changed the transfer case and driveshaft and installed a transfer case saver. The old slip yoke was scored up and the tailbushing was worn. After changing the t-case/ driveshaft there was no effect, it is the exact same. When its vibrating, if i pull the t-case shifter into 4x4 the vibration goes away instantly. Any ideas on what could be causing it? I dont understand how its still doing it after replacing the driveshaft and t-case (and the replacement parts worked fine on the truck they came off)
Thanks in advance for any help,
kevin m.
kevin m.
