Engine/Transmission (1998.5 - 2002) Tryng to drop weight
Engine/Transmission (1998.5 - 2002) Oil sender on the 01 HO
Engine/Transmission (1994 - 1998) transfercase vacuum switch
I have a 2001 extended cab short bed truck and im trying to get down to 6500 LBS. Last year i was at 7200 LBS with me and with full fuel. I was wondering if anyone know how to drop alot of weight. Im thinking about dropping the rear sway bar, does anyone know how heavy it is and is their a big difference in the way it will drive, i have already took the rear bumber off, seat out except for the pass and driver.
OK I'm curios :confused: Why would you want to remove valuable parts that hundreds of hours of engineering went in to, just to be a few pounds lighter :eek: Ever think about Fiberglass hoods and doors. Should be lots of weight reduction there or even remove the Bed and go with a light aluminum flat bed.
Ill State Pullers Acc has put the stock diesel class in with the alter gassers. Their weight class is 6500lbs so i need to get to the weight. The problem is that i need to put alot of safty equiptment so i figure that i need to weigh about 6200lbs to be safe.
