So I was able to get ahold of a TS MVP box to play with for a bit after chatting it up with Dennis Last weekend. For those of you that don't know, TS has not abandoned us 24v guys. They have been developing the box for quite some time for the crowd that does not want to tap the wire, but wants more power than the conventional plug-n-play boxes offer. Installation was a snap, It was in in less than 15 minutes.
I previously ran a Bluechip FMS with a VA V5 for timing. The combo worked pretty well, and of all the other timing boxes I have run with the FMS the VA seemed to provide the biggest kick in the pants down low. Not that I did not believe that the MVP was going to work, but as I tend to be with 24v parts, I was not expecting crazy results from "another timing box. "
I was wrong.
This thing hits harder down low than any other timing box I have ever used. It is verrrrry smooth all the way through the RPM band, and does not feel spiky nor does it feel good on the bottom and then fade. It pulls... ... hard... ... all the way through the RPM band. I first ran the truck with the MVP only. Did I mention it is adjustable? TS has either a 3 position switch or an infinitely adjustable knob like the MP8. I went with the knob because I tend to "fine tune" stuff.
Anyway, with the MPV at 50%, it felt like it was pulling as hard as the VA. The truck was also noticeably cleaner... ... even off idle. Then I turned it all the way up and was not prepared for the results. It was pulling like I had the FMS on 20%, but the FMS was off. After blasting around town for a bit and calling Dennis to report my results, I informed him that I was not sure about flipping the FMS on
he told me to go ahead and throw the fuel to it, so I did and let me just say that even at 31% on the FMS, you better have the truck pointed straight. It hit harder down low than the truck ever has. EGT's were down, and once the charger was up, it was cleaner to boot. I was unable to get in some full-blown "hold my beer" hits, but I plan on sneaking up to Steele for test-n-tune Sunday to get in a lap or two.
I am very impressed with this box. It definitely woke the truck up more than I expected, and the truck just runs like a raped ape now. For anyone running a fuel-only box like the FMS or TST, the MVP should be on your "economic stimulus check" wish list. It impressed the poo out of me. I may try to dyno it back 2 back with the VA at the Comp D race in a few weeks on Dunbar's dyno so we can get some numbers up for everyone.
I was wrong.
