I seen the right up in the last issue, but I was wondering if there has to be a TSB before Dodge can replace it with correct one. First time I checked my filter was at 2500 miles clean on top bottom side had one little small lite sooty spot , always showed about 35% restriction since new. Reset minder and checked again at 8800 miles. Filter pretty filthy sooty, lite oilly residue, but still not as dirty as some I seen in pics on other post. Restriction was around 50% or so, took the filter out and took a air hose to it from top side down, helped a little but not much improvement in the looks of the filter. Reset the minder, next day after driving the truck, minder back up to 50% or so. Checked it again at 10,350 miles looked about the same at 8800 miles done the same with the air hose on the filter and reset the minder, now showing 0% restriction been driving it for about a week now and checking it every other day minder still showing 0% restriction. The manual makes a statment that under normal driving that a filter is to be never inspected depend on the Filter minder to let you know when to change it. Now if you have a person that goes by the book and never checks it (the filter) and the minder is showing 0% restriction or slightly greater and a problem occurs down the road with dirt being sucked into the engine who's liable you or DC. :-{}
