TowPro said:What is this "overrunning clutch pulley on the generator" thing you talk about?
SELLUFISHMAN said:Anyone Have The Tsb Number For The Pulley Fix ?
JRD said:Wouldnt the extra engine cooling and oil pressure correction reading just make the ECM send different signals to the gauge since they are nothing but security blankets and not actual readings anyway?
swexlin said:The belt chirp TSB was brought about as a result of some of the early belt shredding issues that some of us 04. 5 and 05 owners had. Reduces stress on the belt at shutdown.
Just put the belt on correctly and the problem is fixed
swexlin said:No, it's not. Do a search on here and on DTR for "belt shredding" and you will have hours of reading. Belt chirping due to high compression shutdown is normal for all diesels, but, for whatever reason, the 04. 5s and 05s had issues with some of us shredding belts for no good reason. My original one went back in August 2004 with only 5400 miles on the odo. At the time, the TSB didn't exist, and dealer just replaced the belt, which has been fine (Knock wood) since. .
These 3rd gens seem to put even MORE stress on the belts at engine shutdown, and this TSB will help to lessen that, which will lessen belt wear and hopefully lessen the chances of premature failure, which more me, necessitated a ride on a flatbed to the dealer.
You pretty much confirmed my diagnosis that the tsb had nothing to with belt shredding. Just install it correctly and all is fine
How would you know if your belt was installed correctly, It failed in 5,000 miles
and lasted only about six months when dealerships found that some of the belts had been installed incorrectly from the factory.
