TSB Long Crank
power pup and outlook monitor
Should i remove the curved vains in the elbow
I have read on here that there is a TSB for long crank for 06's. Mine used to do it once a week or so, now it's probably once a day. Usually when it's hot out and has been driven a while. Always fires, never a problem there, wanted to know who had it done and if it helped the problem?
I think it's TSB # 14-003-06 or 18-003-06 THanks!
Tyhanks for the reply, I am pretty certain no cracked injectors for me. . Runs great, smooth, no smoke of any color... 22 MPG empty, 14 pulling . .
My 04. 5 would do it time to time. I have found that helps is to turn the key on leave it there for a few seconds before starting. Seems the computer needs to boot up. Maybe I'm just smokin' crack.
Mine used to do it, but since it's been reflashed it doesn't do it anymore. It seems to be hit and miss with some trucks. My truck was also giving a big cloud of white smoke on a cold startup, which is why I had it reflashed to begin with.
Thanks everyone, just got back from the dealer and sure enough I had the flash done 18-003-06 as well as some other updates. Fires right up!! I did notice that my idle is now at about 800 RPM's. Seems a tad bit higher than it was before but idles the same as my 02. Seems to have a bit more power as well. COuld be just me...
