hdm48 thanks for the info that is what i was looking for. got it printed. i am wondering if anybody knows for sure on cowl crack if the water leaks around the vent on dr. side down in. that is where mine is coming in. removed side vent it seemed like it was sealed very tight with foam seals and wheather adhesive. with vent removed and run water on corner of cowl most water you can see looking through the vent hole goes down throgh middle not entering truck. and some of the water drips inside truck. want to make sure have cowl crack problem before going through all the work. any reply would be great for this rookie ctd owner
thanks
hoss
