There has been a lot of discussion in previous threads and post here lately to try to explain and possible get a better understanding of Cummins 6. 7L Emmission's Regeneration process. Not to negate or to dismiss any of the previous posts or threads here is my "two cents worth".
First off the Environmental Protection Agency (EPA) and The California Air Resources Board (CARB) both mandated that both Oxides of Nitrogen (NOx) and Particulate Matter("Soot") on diesel engines be reduced by 90% from the 2004 levels by the year 2007. Thus the reason for the Exhaust Aftertreatment
system on the 6. 7L diesel engine. I will try to explain the Aftertreatment process and the different Nix operation in my next post.
After the trucks where built and put on the market and sold it was discovered that the exhaust aftertreatment system was not operating as it was designed to operate. The vehicles were building up and excessive amount of particulate matter (soot) in the DPF (diesel particulate filter) and that the procedure used to enable the exhaust aftertreatment system to process the particulate matter, called regeneration, was flawed. The problem was found to be a Powertrain Control Module (PCM,Computer) application software issue. The PCM application software program was revised and updated to enable the exhaust aftertreatment system to process the particulate matter more efficiently. The application software program was then issued and made available to dealer technicians to install and reprogram PCM's on previously sold vehicles along with a technical service bulletin (TSB) explaining the reason for and the procedure to reprogram the PCM. The technical service bulletin number for the reprogram is 18-033-07. Since the TSB has been issued it has been update and rewritten two times with the last one being numbered 18-033-07 Rev. B. and dated June 28 2007. The TSB revisions do not change the PCM application software, they just better explain and update the procedure for reprograming the PCM and add to the diagnostic steps for determining if the reprogram of the software is operating correctly. Also this bulletin covers the DH/D1 body style truck only which is the truck built with a bed on it, there is a different TSB and reprogram for the Cab and Chassis truck.
