I just installed a TST PowerMax CR on my 06 and I have a few problems.
First the thing is setting of codes like crazy. When I first started the truck I got 0514, 0073, and 0107. I know that I causes 0514 and 0073 by powering up the unit before I plugged the ambient air temp sensor back in the intake. I"m not sure why 0107 (map sensor voltage too low) would have been set.
I took the truck for a short test drive on 3x3 and every thing was fine. The power was smooth and the engine ran fine without any issues. I parked the truck for a couple of hours before the next restart. The second time I drove it the engine missed a few times under little to no throttle (going about 15-20 mph. ). This caused the check a tone to go off and tripped a code 0336 for crank sensor performance. Now ever time I start the truck I get a strange tone from the dash that I assume is from setting 0336 again.
The next problem didn't start happening until after the 0336 code was set.
On any setting other than 0x0 (stock) the injectors make noises when you let off the throttle. Not every time. I can make it happen by reducing throttle just as the engine starts to really pull AND the transmission is ready to shift. It sounds like the injectors start to crackle.
I'm going to buy a scan tool today so I can clear the codes for a fresh start. I want to use the bypass plugs to see if it still sets codes. If it does that I have a problem in the harness. If not I have a problem with the box.
I need to call TST tomorrow and see what they say. I'm guess I'll have to send the unit back for programing.
I've done a search and came up with lots of issues just like my but never any real answers or solutions.
Anyone got some answers?
Thanks
Mike
Thanks
Mike
