TST and Injectors question
I Got My Fancy New PDR Transmission Today!
When should I change out the transmission fluid?
I have been emailing back and forth with Don M regarding some injectors for my truck and was told that there Flux injectors were specifically designed for the TST CR box plus they are only 40hp, I am not doubting him in any way but I was also thinking about getting Diesel Dynamics 100hp injectors and now I have this big question mark in my mind about certain injectors being ideal with certain boxes. Can any of you guy's educate me a little about this and tell me what you think. Thanks, Mike
One thing though... You are comparing two totally different injectors
One EDM - one extudehoned
And that 40 hp rating is only on a stock truck... I THINK it is more with a duration box
Call Diesel Dynamics, and ask how much they picked up on thier 05 with the juice and a set of dd3's (when they added the dd3's)
ON EDIT - Check this thread - Kieth says they made 501 with juice and EZ and dd2's and a jammer
But 410 on JUST the juice - That should tell you that Extrudehoned are not the right combo with duration (and they even had a turbo!!)
If you take an injector that makes 40 HP with stock fueling and then add duration on top of that then it will begin to multiply the power output for that given injector. Don has made some HUGE power on that 40 HP injector (40 is the bigger of the two he is making) he has been able to suck the fuel rail dry with the 40's, TST, and his very mild pressure box.
