tst boost elbow
Cimmins Powerstore
Shifter knobs found at Charlotte Motor Speedway
Has anyone ever installed JUST a boost elbow from tst? I did and got 5 more lbs boost. I intend to add an "ottomind" from BanksPower. Got any idea how this combo will work? Thanks.
DO you have a boost module? What year is your truck? Without the boost module the ecm should have detected an overboost and thrown a code (check engine light)!
98. 5 3500 SLT Quad 6X6 * 3:54 Auto * Waterfall black/red * Custom dually flaps * Rhino lining * All acc's w/leather * Muth signal mirrors * Catz MSC's * 55watt back up lights * Optima Red Tops * 80/100 Head Lights * BD exhaust brake * Banks EGT/Boost/Temp gauges * Mag-Hytec DC&TP * SS bug screen and fender trim * SS Stull diamond line running boards * SS 4" turn down * grill inserts
My Dually
95 Dodge Ram, mechanical FI
tmarti,
My 12 valve is a '95/auto,and the only thing I have on it so far is a TST boost elbow. The engine may have a little more headroom because boost isn't being dumped,but it sure didn't make more power... you need more fuel to make more power.
I'm not into the Banks stuff,but I'm pretty sure the Ottomind is a 24 valve fueling electronic box... isn't it? It's not gonna work on a 12 valve. You'll need to install a fuel plate.
-Mike
'00 2500,QC,4wd,LWB,Dark Garnet,6spd,3. 54lsd,SLT,DD stage II,Psychotty air,10-level PM3,Jacobs ebrake,Isspro pyro & boost gauges,2wd-low,Airoquip fuel lines,Smittybilt nerfs,BFG 285/75 AT's
'95 2500,Reg-cab,2wd,LWB,White/Star silver,Automatic,3. 54,SLT,Michelin 265/75
I installed a boost elbow after I pushed the plate full forward on my 97. Pulling 35lbs of boost now at WOT. Before I installed the elbow I could only run it up to about 20lbs.
Curtis Harris
1997 3500 Club Cab
"CASPER"
Check out the Lone Star TDR
TST can sell you a Power Kit which in your case means just a torque plate ( and installation instructions) because you already have the boost control. Then you will get enough fueling to use the boost increase. Moderate cost, very effective, excellent power increase.
