Engine/Transmission (1998.5 - 2002) TST Boxes?
Engine/Transmission (1998.5 - 2002) 2002 Auto lockup Question
Engine/Transmission (1994 - 1998) Check your fan!!!!!!!
Can anyone tell me about the TST Powermax 2 Module?
What sort of performance mods do you all see with this box?
Does this box have a built in boost module to inhibit defueling?
Does the Powermax 2 require you to tap into the pump wire?
I had the Power Max 2, it does require you to tap the pump wire, and is not adustable, it's either on, or off. It was enough power for a little while, then upgraded to the Power Max Comp adjustable, far superior, IMO. Team it up with an Edge EZ, or VA, and it's awesome power.
Later, Rob
Ditto to what Rob said. If you can get a good deal on the PM2, go for it. If you are considering this box as new purchase, I'd go with the PM3 and remote.
Scott W.
With just the power max 3 adj no other mods do you get any smoke if so at what level does it start to let it smoke a little
