Well lots of interesting responses on this thread.
i have no transmission mods. i don't do tractor pulls. i don't race people on the street. i'd just like to increase available power for towing.
My advise is to stay away from the 10 plate with no transmission upgrades and no gauges,but,it is your truck. The 11 plate,a 14cm exhaust housing and some timing will allow you to do what you seek easily and have alot less exhaust temps than just "adding" a 10 plate. Do the gauge install first before you attempt any modifications. Also keep in mind a clutch and input shaft upgrade will end up being necessary even with this plate.
boondock, who is bragging about a 10 plate and no slippage I ask this...
Do you feel that you are living on borrowed time or maybe your tune-up is off a touch?. The 10 plate alone will hit the clutch and cause slippage easily and milage doesn't matter from what I have seen. I know owners who have twisted input shafts or snapped them and fried clutches with a properly tuned 10 plate equipped truck. Please give the guy who asked good info and not a load of BS. The mods you are claiming to have would make a stock clutch assembly go screaming loudly back to the factory where it was made.
Howard. .
With the 5 plate having been designed for a automatic truck which has less fuel to begin with its easy to understand how you have egt problems. A 10 plate and 16 housing will help ease your egt pains,but,will not solve them.
The 12 plate. .
While its not rated much over the factory specs it probably one of the most under rated plates made. With a proper tune up,I have seen some trucks equipped with this plate lay down nice numbers and have little egt concerns. Egts will still be higher than stock but are certainly more managable than the other plates.
Keep in mind when the addition of more fuel is made that you WILL need to balance it out with more air and a way to remove the heated gasses. While the addition of a aftermarket air intake is a well needed addition you will need to do something to help the motor breathe easier and allow the exhaust gasses to escape faster. Once you get decide on the bigger fueling plates a aftermarket turbo with more exhaust housing to add air and help remove the gasses will be a necessity. Joe D summed it up best along time ago. . Air+fuel=Power,some may want to find that article and brush up on it some as it will help answer alot of the questions.
Research,research,research before opening the wallet and spending will help give you the best bang for your buck and allow for longevity of your ride... ... ... . Andy
