Originally posted by 01smokinram
It would help if you had it stacked with an EZ. The tst only does fuel,so has a little lag on bottom end. But that is normal for that box.
Originally posted by Snow man
the drag comp takes better advantage of this,and has much better low end/mid range power than a wire tap only box like the PM3. He's looking to reduce his 1/4 ET and has huge tires,IMO the Drag Comp is the best bang both for the buck,and for power. Not to mention the low speed smoke /fueling adjustments that are only avaliable on the comp box,these are a lifesaver once you have big injectors.
You ought to try a Custom programmed Edge Comp!
Even more fun!
If i could fuel hard to 3600,like a 12V Id be
