TST Standard or Twins program. Whats the difference?
How do I find a boost leak?
Hum And Vibration
Standard is what I have and is minimal on turbo damage, it doesn't fuel until 12psi of boost. The twins version isn't as laggy, because it comes on at 4psi. check out www.tomeygun.com he has dyno charts of his SO with the edge ez stacked. There are times I wish I had both or could switch from one to the other.
Blacksdieselhp said:
Just wandering what the differences are in the standard and twins program.
05MX is correct...
Singles/Regular Program:
4psi - 0% fuel
12psi - 1% fuel (starting to fuel linear).
35psi - 100% fuel (all fuel your getting is there)
TWINS program "old" one:
1psi - 0% fuel
4psi - 1% fuel (starting to fuel linear)
12psi - 100% fuel (all fuel your getting is there)
So you could see where when you have an aftermarket single big turbo, you need the fuel down low to get that sucker to spool fast
I know some people might want to go with the Twins program on a Stock turbo, But we know what that does, It flexes the shaft and the blades can make contact with the housing, opps, turbo heaven :-laf
Is there 2 different types of twin programs seems I remember someone saying there is a new and older twins program. Just wondering Im going to go with TST on my 03 and I want the fuel to come on asap.
Jeff_K said:
According to TST there are 2 versions of the twins program for the 03/04 trucks, but only one for the 04. 5+
Anybody know the diffrence there? Is it HO/SO?
-Scott
