tst twins programmer
06' Turbo Lag?
Upgrade to twins from SPS62?
I am looking at getting the tst for my truck. Would like to know the difference from the stock tst programmer and the twin programmer on the 2003. Old girl has twins,fass,ported,studs,fire rings,injectors and full dtt. Truck is a daily driver and still will be. Do tow at times but very seldom over 15000. Just a few time a year. Mainly a daily driver and work truck and have to kill a few hot rods now and then. I feel so bad when i crush them with a 4x4 diesel. :-laf Would like to here of real world experience with the two and similar set up and usees. :)
To make it simple, the difference between the two is that the twins program adds fuel alot sooner than the standard program, I think around 12psi or sooner. With your setup, you definatly need to upgrade to the twins program, it will help you a ton. Also, tst offers (2) different twins programs, so make sure you ask for the original program which was made for the '03's. Have fun, I know I do!
chris
i would get the twins program depending on how large your twins are, i dont know if i would run it with small twins, it might be too violent to tow with, oh well just get the twins program it smokes more for a second then gone with boost..... Oo.
There are a lot of people who run this program. Since you have twin turbos this program will help you out with adding a ton of fuel right away. It is very aggressive on the higher settings for daily driving, and like TCluff said, it smokes alot. I think to have your tst reprogrammed to the "twins" is only $50. You won't be sorry you did.
Standad Program starts to fuel aggressively @ 12psi of boost and full fueling at 24psi. The twins program fuels aggresively at around 2 psi and full fuels around 12psi. Much harder on the bottom end. Hope this helps.
chris
Just for clairification. Are you saying the "Original" TST program that was eating all the turbo's, is now a twin program? I know they changed the "Original" program because it was so harsh on turbos.
Well I like my TST w/twins on my single II SPS66. I would think it is the only way to go with twins of any kind.
Thanks everyone. I called mark yesterday and told him what i have and what i want to do. So i have a twin program in route. :p
