TT Shopping - first time
48ft trailer
2001 Montana 2955
Trying to assemble the mixed bag of opinions on here about travel trailers. Looking to keep cost to about $15k and have found the following:
1. Doing our own looking, was most impressed with a 26' Prowler - new (translate - eat the depreciation) but with good warranties on appliances, roof, frame, etc.
2. Many people have posted here about being happy with Prowlers. BUT - many people have posted about poor quality of Fleetwood - who makes Prowler.
What's the scoop on Prowler quality? What should I look for? This trailer would see a lot of mountain and cold weather use (December elk hunt!) so I'm interested to know how well insulated they are and whether the fluid systems are protected from freezing.
More opinions please!
Thanks,
JimD
For the money, you can't beat the quality of the Artic Fox/ Nash line of trailers. They are a notch above Prowler, with no big corporate overhead.
Just my opinion.
Chris
Everyone has an opinion. I like my terry. It is made by fleetwood who is the maker of avions. I think all will agree that avions are great. I think you will like the prowler. When I ordered my terry we got the 4 seasons camping package. Should be able to get it on a Prowler. My 2 cents.
I have one I bought used (didn't eat the depreciation :) ) and have had 0 problems with it. I think it's a bargain considering the price.
However...
I haven't, and will NEVER buy a trailer I can't inspect first. My suggestion is to buy used, but if you must buy new, buy off the lot so you can check it out before you sign on the line...
Thanks,
JimD
Our first travel trailer was a 1989 Wilderness Yukon by Fleetwood. The Yukon was the economy, unadorned version, and they don't build it any more. Wilderness models now fill that niche. We discovered some things about the way Fleetwood builds trailers during the time that we owned it. Our Fleetwood experience was based on that trailer, discussions with the factory, with service facilities, and other owners. When we replaced it, we didn't buy Fleetwood.
==Fleetwood builds trailers at several different locations. Their entry level trailers, Yukon, Wilderness and Prowler were at the time built at the same facility in Rialto, CA. Most of the labor we saw was unskilled to semiskilled, which might explain some of our experiences. Terry and other lines were built elsewhere, and may be of better quality.
==Many of the trailer's components seemed to be discontinued closeouts. When something broke, there was no way to get another one like it. Even the components that were industry standard items weren't on Fleetwoods. Replacing many of the component thingys required modifying the structure or the attaching point.
==The fresh water tank inlet and the fresh water tank did not have the same size fill pipe fitting. Fleetwood dealt with that problem at the factory by just jamming the semi-rigid fill pipe onto the larger fitting until it stuck there. It leaked from day 1. The dealer's service department was incapable of fixing that (or anything else), so I made up a Rube Goldberg adapter that lasted as long as we owned the trailer.
==One of the semiskilled workers at the assembly plant drove a screw part way into the top of a rafter, for no apparent reason, before the roof was installed. That worried a hole into the roof. Fleetwood replaced the roof (at the factory) with no argument, and they were very accommodating. (Actually, they were surprisingly friendly and helpful. ) But the roof had a pin hole leak, anyway.
==The pinhole leak in the roof caused rot at the left front corner, so I had to remove much of the aluminum skin to fix it. When I had the skin off, I discovered yet more production shortcuts or bad workmanship (pick one):
----Where studs and crossmembers were a little short and didn't match up exactly, the production line people dealt with it by driving in an incredibly high number of air staples, as if the staples would work as glue.
----The fiberglass insulation, touted as R-7, was very spotty. In some places, there was no insulation at all. Where the insulation existed, it had been wrapped over the framework just before the skin had been stapled on. No effort had been made to fit the insulation into the wall and ceiling spaces, and in some cases, the R-7 roll had been stretched to cover just a little farther. The roll may have been R-7, but the result wasn't.
===The trailer was skinned with long aluminum sheets with formed joints. No caulk had been placed into the joins, and the joins were loose. When we towed in the rain, we got water seeping in along the front wall. Again, the dealer could not fix that.
===The factory saved a few bucks by using cheap tape sealer rather than the slightly more expensive butyl tape sealer on assembly. The cheap stuff seems to be oil saturated clay, and it dries out and fails. We had lots of leaks from that. The butyl lasts much longer and seals better in the first place.
===The axle mounts had been welded on to the trailer slightly out of line, or it had been damaged in transit. We were never able to tell which. We could not keep the left front tire from wearing out. (My neighbor's 2001 Prowler has the same problem. )
===The underside was sheathed with PVC or HDPE sheets air stapled to the plywood floor. The staples were not sealed, which provided a conduit for moisture. Fortunately, I discovered that before we used it extensively, and I was able to seal them. That involved two hours under the trailer, on my back, with a caulk gun and plastic spreader.
We used the trailer in cold weather, and never froze the internal pipes. However, we had to keep the furnace operating a lot to prevent the freezing and stay warm. That's not limited to Fleetwood, and it is still something we have to do with our new one. When it's not being used in cold weather, any trailer's water lines MUST be drained and blown out with air. Our eventual insulation discovery later explained why we had to use the Yukon's furnace so much.
None of the problems that we had would have been found through a walk-thru or inspection of the interior.
Maybe we got the lemon and everyone else's was just fine. Maybe they're not like that now. We used the trailer a lot, and enjoyed our trips with it (behind a full size Jeep, getting 6 mpg on premium gas). We eventually outgrew it. Unfortunately, the nature of our experiences seemed pretty widespread as we talked with dealers and owners. I see a lot of Prowler and Wilderness trailers on the road, but we won't buy another one.
Shopping for a TT
Be wary of front slides as they add a lot to the tongue weight of a TT. I have an 28' Artic fox w/front slide. dry tongue weight is 900 lbs. When its loaded the tongue weight is too much for the stock hitch. I had to upgrade. I setteled for a heavy duty pullrite. Rides just like a 5er. 2k tongue weight, 20k trailer weight. Not cheap either. Of course I didn't know about any of this until after I bought the TT.
Tongue weight is good. REGARDLESS of the trailer you decide, ALWAYS tow with the tongue weight 13-15% of GTW.
My first RV was a 1992 Prowler TT floor plan 32Y. My experience with Fleetwood and it's dealers was over all positive. It comes with industry standard apliances (Magic Chef, Atwood, Colman AC, Suburban water heaters etc) That's all run of the mill stuff! It was a great 'ol TT. So good I put a motorcylce rack on the rear and towed with a 280lbs four stroke on the back. All told including the rack I probably hung 375lbs on the rear. BUT I ALWAYS loaded heavy in the front. Soda, beer, tools, etc.
I was so satified after 8 years and approximately 40,000 trailer miles, I bought what's in my signature: Another Fleetwood but this time a 5er. I bought all I could aford. There are a lot better 5ers out there at different costs but I'm convinced there's no other on the market that offers more floor space for the money than the 34-5L floor plan. My buddy who owns a 2001 38' Monaco Diplomat (8. 3 Cummins, 6sp Allison) with slide calls my 5er "Ian's dance hall"!
The only thing I did that I think was smart is I imediately changed out the load range C 15" tires that came with my '92 TT and up graded to 15" load range D. That was it for disappointments. I sure have my wear and tear stories but none of it is Fleetwood's fault.
What ever you decide, take it out locally as soon as you can. That will disclose anything that may need attention before you set out and really travel.
- Ian.
Oki-Go,
No, we do not ALL agree that Avions are great. I had one that was bought new in 1995 and couldn't even find all the warranty issues in the first year in order to get them fixed.
The specific problems I had with the Avion were not the same as Matt's, with his Wilderness, but the situation was similar.
Two that I remember were:
1. The water line to the kitchen sink had a slow leak the first time it was pressurized. Inspection showed that the copper tubing had been improperly sweated.
2. The pressure line that supplied water to the black tank shower (the spray inside the tank that washes down the sides after the tank is dumped) was not connected to anything. The first time I used it, water POURED from the basement storage compartment opposite the fitting. Fortuntately everything in that compartment was waterproof.
I can't remember the other six to ten items that I had the dealer work on under warranty.
This trailer is now seven years old and is literally falling apart. The moulding on the inside that covers wiring and "gussies up" the trailer is falling off the walls because it was attached so poorly.
I urge all TDR members (and anyone else too) to avoid Fleetwood products. Even the expensive, top-of-the-line Avion is a piece of junk.
Loren
Jim,
I know that owning a new trailer is a great thing, but I urge you to consider buying used, especially since this is your first one.
Trailers are like boats, in that you never get the one you really want the first time. If you try RV'ing for six months or a year with a cheaper, used trailer, you won't take such a major hit when you want to trade it for the trailer you really want.
My experience is that buying a high-quality, used trailer beats buying a poor-quality, new trailer every time, even if the price is the same. This is especially true if you tow it a lot. (as opposed to leaving it parked) A top-quality trailer will stand up much better but will still be very reasonably priced if you buy it used.
You will find that the differences between quality trailers and poor trailers are much greater than the differences between expensive cars and cheap cars. With autos, even the cheap ones will get the job done, but with less luxury, etc. That's not true with RV's. The cheap ones will break.
I think that most RV'ers will agree that Airstreams are excellent trailers. My wife and I also like Holiday Ramblers. We lived in one when we were first married, and own a second one (bought used) now. The Newmar trailers (London-Aire, Mountain-Aire, etc. ) seem to have a good reputation. I'm not familiar enough with the western-made trailers to have an opinion, but I'm sure there are members who can advise you on those.
In closing, I'd again like to urge you to buy a used trailer. You can save about 40-60% of the price of a new one, and even if you have to pay to have a few things fixed, you will come out WAY ahead. Don't get the new Airstream until you are sure that's what you will keep for the next 10-20 years.
Happy Hunting.
Loren
Buy Used
DITTO! That's exatally what we did. First of all the truck was a huge inverted investement since the moment you drive it off the lot it does'nt seem to be worth what you paid for it anymore. Second, is the fact that if you've never owned a TT or 5er, you don't (and I mean,you don't) want to sink BIG bucks into some thing you have no concept of what owning such an item entails. We paid 5k for our first TT and broke ourselves in on it. After 2yrs we were able to sell it for what we paid for it and had a much better idea of exatally what we personally required in comfort and quality, not to mention what to avoid in the purchase of a new a new TT. Besides the depreciation on a TT is much greater than the Truck.
Jim D:
I've owned four trailers all bought used. The last three were Holiday Ramblers and all have been excellant. My latest is a 96 model, 36 foot fifth wheel with two slides. Paid 25,900 for it in 2000. Traded in a 91, 32 foot tag along and got what I paid for it less $1000 after using for 4 years. I live in it full time working and consider it cheap rent.
I vote for the buy upscale used rather than new low end. Holiday Rambler is my choice but London Aire, Kountry Aire, Teton are equal. Find the one that has been taken care of. They won't be hard to spot.
Barry, the moderator of this forum, is a dealer of used RVs and has been very helpful to new buyers. His web site is http://www.autorvexchange.com/.
Charley:D
I looked at trailers for several years before picking one. The wood framed ones are either stapled or screwed together. The staples can shake out if gravel- or off-roading with it. The screws tend to split the wood. I looked at Airstream finally, and bought it. Riveted aluminum monocoque frame, independent henschen suspension system, quality, and layout impressed me. Cost was about double what I could have gotten a Terry for, though. Seven years later I am still pleased with my choice.
Jim D. -I had a Prowler TT. I got fairly good service with it . In 1994 I found a 5 year old Alpenlite 5th wheel. The first discovery was how much better it pulls than tag alongs do. The second thing was the discovery that my F--d was not up to the task. :rolleyes: Along comes my first Cummins powered Dodge. :D When I got ready to upgrade to a new trailer I did not even consider anything other than Alpenlite--that is how satisfied I am. See profile for details of my truck and trailer . :cool: The point was made about premium trailers & value. :) It cost me less than $2k to pull my '89 for 5 years--& I traded it in!! :p (saving the time & trouble of selling it myself) :D
By all means check with Barry if he is any where within reasonable distance to you and he will treat you right. He just helped me find a fantastic used trailer. Thanks Barry for all the help, we love the the trailer.
TT
Check the Nash out. Made by Northwood out of Le Grande, Or. The price is alright and the trailer is will built. lot of different floorplans, too. Might want to check Thiunder RV. They have a website,too.
