BMcQuillan
Hello, My truck is a 2005 2500 4wd 5.9 and 48re. Has been difficult to get into park, cable popped off the shift bracket at the trans. Got it temporarily working by readjusting the shift cable. The nylon connector on the trans end of the cable is worn, as well as heavy rust on the shifter bracket as well. The ball end looks like it has diminished in size due to rusting. I now have a new cable and shift bracket. After researching with my factory shop manual, I realize the TTVA has to be removed in order to replace the shift bracket. Any tips, tricks, or horror stories form people who have already done this would be appreciated.
The second question, is the stock fuel filter canister unit still available at all? I replaced the line and banjo bolt/ check valve that goes to the back of the head a couple of months ago. Fun job! A couple of the other lines are really crunchy as well as the unit itself. It looks like more leaks waiting to happen. Any info on this would be appreciated also. That's what living in Mass. does to your stuff!
