i just got done installing my ats aurora plus twins on my 06. the kit uses the factory turbo and a aurora 5000. it took me forever to get these suckers installed but some of that time was do to rain, (no garage currently). the kit has me enlarge the factory turbos wastgate opening to a 1inch diameter and set the turbos wastgate preload to 5/16ths which suposidy
"For optimal performance, set the Wastegate preload to . 312” (5/16”);
exactly 1. 5 turns of the clevis. Thread the clevis out until it slides on the
pin easily, then turn the clevis back 7. 5 turns to set the preload. Too much
preload will cause high EGT's and too little will cause slow throttle
response. Once the preload is correctly set pull the clevis onto the lever
pin. Tighten the lock nut. Secure the clevis on the lever using the original
e-clip. " (ATS Installation manual).
after doing what the installation manual told me, the clevis is now holding the wastgate slightly open. if im not mistaken wouldn't preload imply that its holding the wastgate closed. when looking at the turbo you and see that the clevis is threaded out about . 5 of an inch further then it was at its stock setting. driving the truck it feels good but i feel as if there should be more down low. the turbos dont real kick in until about 1500ish or so and top out at 35psi at WOT. also lots of black smoke down low more than with just the stock turbo. no egt problem, also smarty is set on 4+timing rp=stock tqm=2, no injectors installed. i was thinking about closing the wastgate more and taking the truck for another test drive but it will probably be an hour before it cools enough to touch it. suggestions on how to get turbos to come in sooner would be much appreciated.
