Thanks.
Seemes like I learned new stuff here:-D
So,hvat you recomend me to bye of turbinehousing??
I have been wathing these alternatives:
Banks Power Quick-Turbo Assembly w/ Wastegate Actuator #24052
16cm Turbine Housing
Turbine Housing 16cm Dodge Ram Cummins Diesel 5. 9L 1993 : eBay Motors (item 250563750146 end time Feb-13-10 16:57:00 PST)
Ore maybe you have a better suggestion???
This is a sitat from dodgeraminfo rrom Geno's Garage:
What does the "Wastegate" do, and does it work along with "Boost"?
* The simple explanation: a wastegate limits the maximum boost generated by the turbocharger.
* How it works and what it does: The wastegate uses a pressure activated diaphragm and rod to operate an exhaust bypass around the turbocharger and thus limit the maximum boost that the turbocharger can produce. This permits an engine manufacturer to use a "fast" turbo charger with a small exhaust housing to produce useable boost at low engine speed and load. To prevent excessive boost at higher engine speeds, the wastegate limits the maximum boost to a safe level for the engine, and prevents turbocharger over-speed
Turning up the wastegate will increase the air volume that is stuffed into the cylinder. This *may* reduce the EGT, but will not increase power. How do you get more power? One way: more fuel = more power. To increase the power, the fuel rate must be increased. The boost should only be increased to match the fuel curve for smoke and EGT control. Several tests have been done where a truck was run on a dynamometer, the boost was increased by blocking the wastegate signal, and the truck was re-tested on the Dyno. In every case reported, no power increase was measured.
The 12 Valve engines do not have a problem with excessive boost. For improved performance on pre 94 engines, a 16 sq cm turbine housing is usually the best compromise between low speed boost and high speed exhaust restriction. The stock 12 cm housing on 94+ engines is OK up to about 240 HP, beyond which the small housing restricts the exhaust and raises EGT. A 16 cm housing provides enough low speed boost for an enhanced engine, and the exhaust runs cooler at high speed
Does this means that I do not need wastegate?
Where can I get 16sq cm with wastegate??
