Hey guys quick question. So I’m dealing with a sluggish motor. I have a rebuild kit for the turbo, not really any forward and back play but enough top to bottom or side to side to touch the case if you nudge it that way. No contact with the housing as yet while running. Other thing is I tried manually pushing the actuator rod for the wastegate and it moves freely but just watched it while the motor revved up to 2500-3000 in neutral and it didn’t move at all. Thoughts? Bad turbo internals? Bad actuator? Both? Checked everywhere for boost leaks except the inter cooler itself. One other thing, I have a loss of prime issue going on overnight sometimes, 430k stock motor. All comments appreciated, sorry I can’t supply boost and fuel pressures as I don’t have any gauges for that, just hoping someone with working experience can help me narrow this down. No smoke issues at all, burning clean but only seems to boost in second gear (first and second) or if the truck is running flat or downhill, the smallest hill and it fails to rev past 1800-1900 and boost normally, hits around 2000 historically. I’ve owned this truck for 18 years and want it happy again with your help!
