Do you know what software level your ECM is at? You need the latest software and then the dealer needs to perform TSB 11-003-07. Also what is your idle time and duty cycle? Do you run it hard or just run around town? Do you run with the EB on most of the time?
I don't know if this would be called a turbo cleaning procedure per-se, but during the last visit to my dealer, it was explained to me that DC had given instructions to dealers about a new procedure following a dealer-performed oil change. The dealer proceeded to explain to me (since I change my own oil) that DC has instructed the dealer to basically idle the 6. 7 at moderate to high RPM's for a short time following an oil change. And as it was explained to me, this procedure was necessary to clean soot out of the system.
I hear you. When I get mine back, I am adding the BADP 5'' kit and blocking the EGR I am tired of the dodge BS, 10MPG and I think this is the only way these trucks will ever see 200k to 300k like my past 5. 9L trucks did. I don't understand how the EPA thinks, 30% more fuel =cleaner air. SOMEONE IS MAKING A TON OF MONEY OFF THIS AT $3. 50 PER GAL.
I am getting ready to pick up my truck tomorrow, after dropping it off with P2262 again. I have had my turbo replaced twice. The service advisor (in his limited knowledge) says there was a software update applied (must be recent, as the last turbo was two months ago) and that the truck now passes whatever test they use on the actuator, so no new turbo this time. Of course, my truck only has 8k miles on it. I could still get more turbos before 22. 5 k miles.
Does anyone know what the new SW changes actually are? Are they specific to EGR operation?
Last time I was there the diesel tech also said Dodge was working on some sort of plate/window for the turbo that could be removed to allow cleaning of the actuator/shaft.
And just a tech note - the 240 hp turbocharged Saturn Sky already uses direct injection, and gets 2 mpg better than the 170 mpg base model without direct injection or turbo. According to one review, anyway.
