Engine/Transmission (1998.5 - 2002) Turbo application
Wanting to make sure if a HX35 off my '96 will fit the '02. I think it will. Someone in the know please verify.
Forrest?
Smitty
I'm pretty sure it will work. the waste gate actuator on the '02 mounts to the compressor housing. That might be different than on the '96.
bolt right up got one on my 01 right now. you will need the exaust elbow or put your elbow off the 02 on the older turbo. and you will have to have two bolts to bolt it ut the 96 turbo has no studds. the 02 has two studds on top easy to do. you might also have to drill and tap a hole foe the waste gate line in the compressor housing as some 12v used the sense line from the afc housing some came off the compressor housing like the later hx35's.
