turbo bark 3rd to 4th shift
NV5600 Short shifter
POLL: who has changed turbo on 05 and gets 0299 codes?
i have a 2004 with 48RE auto when it is at 2000 rpms and shifts from 3rd into 4th the turbo barks is it the shift timing or a voltage drop in the trans
That is from the crappy torque converter that is revving so high and then hits lock up. Mine did that until I had DTT fix it :D
My truck used to do the turbo bark thing with my quadzilla race box when shifting on my 48re also. I have since installed the bullydog power pup and have not heard it since when shifting. coobie Oo.
My stock turbo would bark after my tc/trans upgrade when shifting to OD at 2/3 throttle. My SPS66 will bark all the time if I am too agressive with the throttle. It will bark even with all boxes/downloader set to stock.
BigGunZ said:
Is your truck stock?
NO IT HAS SUN COAST CONVERTER HIGH PREFORMANCE CLUTCHS BILLET INPUT AND OUT PUT SHAFT OVER HAULED VALUE BODY AFE AIR INTAKE STAGE 1 KELDERMAN FOUR LINK LIFT KIT AND I USE ALL LE OILS BUT IT STILL BARKED WHEN IT WAS STOCK SHIFTING FROM 3RD INTO 4TH GAER AT 2000RPM
Tell Me If You Use A Fuel Gauge My Stock Reads 6 Psi Under Full Power 9. 5 Cruiseing Down The Hwy The Fass Fuel System Maintain High Fuel Presure Under Full Power
