Turbo boost actuator?????
lift pump drama...
Another shock questions
Ok, Last night the Check engine light came on I did the key on/off thing and came up with code PO243 Turbo boost controll actuator... . I found the wire on the boost controller had chafed through (was rubbing against the wireng harness) and the wire is all greened out and broken. it's too short to fix. any one know where I can get the boost controller? I went to the Mopar parts direct site found the turbo but they don't offer the parts only a compleate asy well over $1400! I don't need a whole turbo just the bost controller... Any info would be great... Thanks... .
2005 Ram 2500 6speed all stock well except for the banks duall exaust... ... .
Just wanted to say thanks again, the parts shower up today and they were even the right ones! For everyone with an 04 and newer truck with the computer controlled waste gate check that the pass side batt ground wire is not up against the actuator thats what aused mine to break/ chafe through. It's easy to see from the pass wheel well.....
