TURBO CHARGER FAILUREs p2262
What is latest ECU reflash?
abs and brakelight
Does any one know what the number for the Holset turbo charger on the 6. 7 litre is ? a Dodge part number would be good but a Cummins part number or a Holset model number would be better ,I am in Australia and we are still trying to deal with the 07 turbo problems we have 25 units some have the 2262 code now and again ,we have cleaned out several turbo charger variable vanes,but i beleive the turbo that are being replaced in the USA now are made with larger tolerences ,so they dont coke up so quickly ,We can get Zero help from Dodge as the vehicles are not under warranty as they are outside the USA. Help with model numbers and what has been done to the turbo systems would be appreciated,we have been able to get the latest flashes for the vehicles from our local dodge Dealer
HELP
Regards Conn
Send an e-mail to "K" at MOPAR4LESS. This woman is the most professional parts person I've run across. She always replies promptly, is always accurate, and goes out of her way to be helpful.
MOPAR4LESS is a large internet parts supplier located in Farmington, NM.
I think P2262 is from soot in the actuator
put the exhaust brake on and drive it some, Try to drive it with the ebrake on often and drive it hard from time to time to clean out the soot. also 2 minute trips with turning the engine off and restarting it will cyle the actuator. Make sure he has the latest software flash which I think is now the AX software
good luck
