I need some help concerning which turbo to get.
You can see by my signature how I'm set up. I don't do any racing, (except to blow off a PSD or two
) just pull a 9500 lb. camptrailer quite often. I have plenty of power but my problem is high etg. 's when pulling a steep grade and then I can't use all that power!
I've been told I need a bigger turbo, but there are too many options and I'm having trouble deciding which to get without breaking the bank!
Kurt hx-40 12 cm2
Piers modified hx-35
Piers modified hx-40
Just a stock hx-40
And then 3-4 different exhaust housings for each!
I'm sure if I could just lower the egt's by 150 - 200 deg. I would be in fat city...
Thanks for any ideas,
Lonnie
Kurt hx-40 12 cm2
Just a stock hx-40
Lonnie
